What code should this be?
BobTPH Joined Jun 5, 2013 11,644 Oct 17, 2022 #2 Transistor, 3 terminal regulator, dual diodes, voltage reference, or others I can’t think of.
Ian0 Joined Aug 7, 2020 13,271 Oct 17, 2022 #3 I think you can eliminate dual diode, voltage regulator or reference because it is called ”Q2”. Regulators and reference would be IC2 or U2, and diodes would be D2. That just leaves JFET, NPN bipolar, PNP bipolar, N-channel MOS or P- channel MOS.
DickCappels Joined Aug 21, 2008 10,661 Oct 17, 2022 #4 ...unless it is a JFET (but nobody seems to be using them these days)
K Thread Starter kiltro Joined Oct 24, 2011 63 Oct 17, 2022 #5 OK so that "1 ( ) or 10" is not of help I guess... I'll have to reverse eng the pcb
K Thread Starter kiltro Joined Oct 24, 2011 63 Oct 17, 2022 #7 MrChips said: MMBT5088 NPN transistor comes up. Click to expand... Oooohh it's a damn "Q" lol
BobTPH Joined Jun 5, 2013 11,644 Oct 17, 2022 #8 MrChips said: MMBT5088 NPN transistor comes up. Click to expand... How did you get to that from the markings on the package?
K Thread Starter kiltro Joined Oct 24, 2011 63 Oct 17, 2022 #9 BobTPH said: How did you get to that from the markings on the package? Click to expand... https://www.sos.sk/pdf/SMD_Catalog.pdf
