I messed around a bit again and discovered it could be possible to make a rechargeable battery using only metallic nickel sheets as the both electrodes.
electrolyte is a saturated solution of sodium sulfate and sodium carbonate to maximize conductivity as much as possible
(while still being reasonably safe and not scary caustic like potassium hydroxide)
it takes a long time to form the electrodes. many hours and hundreds of charge discharge cycles. but it does indeed work from a small test setup using several stacked sheets of nickel foils with a thin separator such as napkins toilet paper tissue or paper towels.
I would really like to know exactly whats going on though. The positive electrode gradually darkens. and the negative electrode is reduced. and if you swap the polarity. the colors swap.
Some kind of nickel oxide forms that allows a voltage potential between metallic nickel. and the other nickel electrode.
