Solid state relay and dimmer
Rufinus
Joined Apr 29, 2020
325
Hello. I´m making a heat treatment oven with 2 heating elements. The PID controls a solid state relay. The question is I need to regulate one of the heat element with a dimmer (I already tried and works nice)
I´m going to connect everithing like that
But I´m not sure it this setup is OK. Since I don´t really know how a SSR works I´m not sure if the dimmer can make interferences with the SSR or the other heat element. What do you think?
Thank you
best regards
MaxHeadRoom
Joined Jul 18, 2013
30,882
See Fairchild App note AN-3006 for zero cross switching style Triac driver, Advantage is Less surge current and no EMI generated.
As per post #2.
Ian0
Joined Aug 7, 2020
13,315
As per post #2.
If you already have zero-crossing SSRs, all you need is a comparator to drive the SSR LED, with a thermistor on one input and a reference on the other. No need for hysteresis.
LowQCab
Joined Nov 6, 2012
5,102
The question is ........
If You already have a PID-Controller,
then why do You need a Dimmer on one Element ?
Do 2 Heating elements running together pop a Circuit-Breaker ?
Rufinus
Joined Apr 29, 2020
325
thanks for your answers.
LowQCab, because I made the oven, and later I realised that it needs more power, buuuuut I don´t have room for a propper long coil, so I had to put a shorter coil of kanthal wire. It´s only 16 ohms and I´m using the dimmer I can to drive only with 6 amps
Rufinus
Joined Apr 29, 2020
325
It is not only that, this oven is going to be used most of the time at 500 ºC to stress relieving in homemathe triode valves. But sometimes I´ll use it for hardening steel so I want the other coil separate of the rest of the circuit so I can turn on only when I need it, but thank you for your interest
