Solenoid Valves Controlled By USB?... Help Needed
ErnieM
Joined Apr 24, 2011
8,415
You connect it across the solenoid coil so it is normally not conducting. It is there to "catch" the rather large inductive voltage kick a solenioid gives off when the power is removed.
Put it in there and the voltage seen by the relay contacts is small and controlled.
Leave it out and the relay will fail sooner rather than later.
ErnieM
Joined Apr 24, 2011
8,415
Place one on each and every solenoid. Best place is right at the solenoid itself.
It goes between the positive (banded end of diode) and the negative wires.
MaxHeadRoom
Joined Jul 18, 2013
30,873
If you are using the proper stake-on terminals for the intended solenoid, you could place the diode lead into the stak-on with the DC conductor.
With these types of connector it does pay to get the proper crimp tool.
Max.
