Soldering Iron Care
Lectraplayer
Joined Jan 2, 2015
123
I have been using my Radioshack soldering iron with 60/40 rosin core, and though I have been keeping a big wad of solder on my iron when I'm not actually flowing solder, I'm gettlng major oxidation and can't keep the crud away with my wet sponge or steel wool. What can I do to correct for this?
DickCappels
Joined Aug 21, 2008
10,661
If your soldering tip is clad with a metal that is not prone to oxidation (chrome, iron, etc.) the problem might be that the cladding has worn away at the tip. Erosion will continue until you replace the tip. Some manufacturers warn to not use water on iron clad tips and they often caution against wiping because that can cause some coatings to wear off.
If your soldering tip is copper, and you are keeping it tinned with solder, then you might want to lower the power a little bit (I use a triac light dimmer on my soldering iron even though it has a clad tip) and only have the iron on when you need to have it on.
Dodgydave
Joined Jun 22, 2012
11,395
if its a copper tip without a coating, it will burn away constantly, if its a tinned copper bit , keep a small amount ot solder on the tip when not in use, and lower the temperature with a light dimmer or half wave diode.
mcgyvr
Joined Oct 15, 2009
5,394
Distilled water only if using a sponge..
Do NOT use steel wool.. Too abrasive..
When done.. Clean tip, turn off power, apply solder to it on both sides.
Radio shack = crap ...so thats more than likely the problem though that and the tip plating is probably already gone..
Pencil irons without temperature control are garbage too.. Too hot and oxides form very quickly..
#12
I asked for a photo because I've never seen, "major oxidation" on a soldering tool. Perhaps because I only buy Weller brand. If that is true, the solution is to buy good quality soldering irons and bypass the need to learn care and feeding of miserable quality tools.
OBW0549
Joined Mar 2, 2015
3,566
I think the best thing you can do to maintain your sanity while working with electronics is invest in a good quality temperature-controlled soldering iron. It doesn't have to be one of the premium digital models; analog temperature control is just fine. I've been using a Weller EC1002 (predecessor to the WES51), and love it. I do quite a lot of soldering and am still using the original set of tips I got with the unit years ago. The temperature can be set at anywhere from 350F to 850F and with a 42 watt heating element, the unit heats up very quickly when I need it to.
When I finish soldering one batch of joints and it's going to be some minutes before I begin the next batch, I just back off the temperature to 450F or so and let the iron idle. I've had no corrosion problems.
Lectraplayer
Joined Jan 2, 2015
123
My Weller gas iron is doing the same. I also have another gas iron that too is oxidised. Those, especially, I call myself babying, but I'm obviously doing something wrong.
My instructors at ITT Tech preached against the wet sponge. Most liked steel wool, but one swears the finger is best, partly stemming from him having frostbite. I can do that as well if I'm fast, but still prefer other tip cleaners such as steel wool and the wet sponge.
ian field
Joined Oct 27, 2012
6,536
The biggest problem I've had with any iron is the buildup of carbonised deposits where the removable tip fits into the iron. In many cases trying to get the bit out for replacement can wreck the iron.
Occasional removal and cleaning is a good maintennance plan, a tips column in one magazine suggests ammonia - but I'm guessing you don't want any of that to soak into the element.
ian field
Joined Oct 27, 2012
6,536
I used iron clad tips in industry for many years, and always with a wet sponge.
The only problem I ever had with that, was if I cleaned the tip too well and didn't use it again straight away the iron plating would oxidise, that meant using some kind of abrasive before I could tin it again.
It didn't take long to learn to re-tin the tip immediately after cleaning it on the sponge.
dl324
Joined Mar 30, 2015
18,356
I think that's BS. I've used my Weller soldering iron with the same tip for almost 40 years and I've always used a wet sponge. I'm still on the original sponge too. I don't solder as much as I used to, but it's seen a large number of hours of use.
BR
Dennis
