Smooth Stepper
Janis59
Joined Aug 21, 2017
1,893
What is smoothe stepper? Stepper motor never turns smooth like do sinus-fed motors. Of course, the microstep regime heavily eases the jump-step character, but anyway it never isn`t completely smooth. That is why we condemned our vacuum levitated crystall growing (Czochralsky) equipment project planned steppermotor (with ulta many microsteps) and installed another solution instead.
Janis59
Joined Aug 21, 2017
1,893
This one.
A CNC motion controller
Push my nose into and have a signalizing smell thats a tradename having no any improvements over existing microstep regime. Thus, Your question is question about the Tradeemark, and in this I have no experience. I am using Chineese 5 Eur controllers not 220 Eur controllers, but don`t think there is significant difference except the well doccumented reliability paper sheet. Thus, the real bill is 5 Eur for gadget and 215 Eur for paper sheet.
DNA Robotics
Joined Jun 13, 2014
670
At the bottom of the product details page it says.
*SmoothStepper Motor signal outputs are only 5V and 24 mA or 32 mA. This will not drive a Stepper Motor directly, and you will need a Motor Driver for each stepper motor.
So you still need Motor Drivers and the best you get is microstepping.
R!f@@
Joined Apr 2, 2009
10,004
Pardon me for limited info provided.
I am planning to buy to install in my CNC.
The one I have is a parallel port card, which is giving me headache. Limited IO and skipping steps if my PC gets buzy at times
I was wondering if any one is using this controller.
27,639
A PC running some non-microspht OS or maybe machine code could possibly do a fair job with simple CNC tasks, maybe. But certainly MS products are not for controls where timing measured in seconds or minutes matters.
And it may be that it is possible to generate smooth speed ramp-ups for stepper drives. But a stepping motor is by definition a stepper and that means not smooth. No matter what it is called, stepping is not smooth.
R!f@@
Joined Apr 2, 2009
10,004
I am using a desktop, and is not used for any other purpose.
and smooth or not is not the issue. I guess no body is using this controller here in this forum. I have done a lot of viewing on the controller. I guess it is one of the best and Ethernet control is better than USB
MrSalts
Joined Apr 2, 2020
2,767
There is some pretty good open source Arduino code that only does G-code to stepper motor control. Instantaneous. No delays for OS checks.
djsfantasi
Joined Apr 11, 2010
9,237
If it’s running a Microsoft desktop, the best you can say is that it’s not running anything else, that you are are of!
Windows has many tasks running in the background that can affect the timing of a foreground app.
27,639
You need to understand that windows top priority is running iit's own housekeeping routines. After that comes checking for updates and patches and such. So there is no promise at all that any other operation will not be delayed for even many seconds.
MaxHeadRoom
Joined Jul 18, 2013
30,686
The motion controller quoted, like others of its ilk, uses the PC and a program such as PC based Mach3/4 etc, as a Trajectory planner and hands over the commands to the external controller.
This eliminates or reduces the effect of what else the PC is doing.
The cards I use, Galil Motion, sit in a PC slot and are self contained and also just use the PC as a HMI, the CNC motion loop is carried out solely and independently by the the card itself.
(12Mhz feedback loop). !
Those that chose to use Mach3/4 alone, then have to be very careful of not running any other PGM at the same time.
27,639
The Galil products are in an entirely different realm as far as capabilities go, from what I have seen. Also a higher quality all around.
MaxHeadRoom
Joined Jul 18, 2013
30,686
I was using them as an example of a separate trajectory controller to the HMI. The OP's SmoothStepper qualifies as this somewhat.
I started using Galil practically since their inception, '80's ?
Reloadron
Joined Jan 15, 2015
7,892
Years ago we were tasked with designing a cladding weld system. The idea was to place a clad weld inside about a 4" stainless steel (316) tube about 3' long. The weld wire was constantan as I recall. The tube rotated at maybe 1 RPM and each revolution was 0.1 inch so ten revolutions covered an inch of travel. It was a long and slow process with absolutely no margin of error. We used 1 stepper motor for weld head travel through the tube on a leadscrew and another stepper motor to control tube rotation. Each motor drove a 50:1 mechanical gearbox. I have long forgotten the leadscrew pitch. This was maybe mid to late 90s must have been late because the PC which controlled everything was an old XT or maybe AT box running Opto 22 hardware on maybe Windows 98. The stepper motors were beast, these were the motors and these were the motor drivers. To get very smooth rotation and travel was a matter the 50:1 gear box reducers. Talk about smooth from a stepper it was all in the gear reduction and quality gear reduction less any backlash. The process ran about 3.5 hours as I recall and it may have been longer. We constantly monitored 5 parameters and recorded them for the entire run process. Weld current was about 200 or 250 amps, arc voltage control about 12.6 volts. Rotational speed of the tube and travel of the tube were constantly recorded. The software was all done in VB 6.0 as I recall. A single burb and we had a very nice piece of scrap. Those Anaheim Automation motors and drivers were at the time the best money could buy and the motors weighed over 10 pounds costing over $1,000 USD each. The controllers were about $700 USD. The motors had 1/2" OD shafts. The weld power supplies were either Lincoln or Miller as we used quite a bit of both. Here nor there. All of the mechanical movement was really super smooth and these were the linked stepper motors full 1.8 degree steps 200 steps per revolution, Those motors delivered dome serious torque. I believe Anaheim Automation is still alive and well. When designed right and the right stepper motor is chosen you can indeed get very smooth operation and precise operation from a stepper.
Slightly off topic but smooth operation from a stepper.
Ron
R!f@@
Joined Apr 2, 2009
10,004
That was the info I was looking for.
So this motion controller can eliminate the issue I get from bzy PC. Right ?
MaxHeadRoom
Joined Jul 18, 2013
30,686
Yes, it should eliminate it, or at least reduce it drastically.
Have you tested it ensuring no other program running while using the motion control?
