Smoke Detector Switch
RodneyB
Joined Apr 28, 2012
698
I am trying to fit a smoke detector to my alarm system. Today I bought the Yale E-SD2 Smoke detector.
I didn't check the specs when I was in the shop, Only to get home and find that it is a stand alone system. I want to connect it into my Telemetry alarm system. I need to have a set of normally open contacts that when close will trigger the input to the Alarm.
Is there some way I can make a small circuit that will give me a closed switch when the Buzzer sounds.
I think the sound comes from a Pizo Transducer. There are three wires RED,BLACK, and GREEN.
I have no idea how to do this
Dodgydave
Joined Jun 22, 2012
11,395
I would look for the number on the chip, for a datasheet or other circuits used, looks like its an Optical type, so probing the receive pin to see what happens when it detects smoke.
