SMD LED with spot size around 1mm?
AlbertHall
Joined Jun 4, 2014
12,629
I am looking for some SMD LEDs which will fit in a 1206 size space but with the light coming from a dot about 1mm diameter. Anyone know of anything like that?
A standard 1206 LED has the light coming from a much larger area.
ronsimpson
Joined Oct 7, 2019
4,708
Some LEDs have a diffused glass and it looks like the entire part emits light.
Some LEDs have a magnifying glass that makes the silicon look much bigger than it is.
Some LEDs have a clear flat glass and you can see the silicon. The silicon can be less than 1mm.
I just found this one:
