"ZD2005 9061 smd led yel 40mcd gullwing pk10"
The above description is all I have to identify a smd led I bought from jcar australia in an otherwise nondescript packet of ten.
I can't find a datasheet for this ID. The staff at the store couldnt help.
I've found reference to this diode here: http://lab.wildthings.io/2019/02/04/leds-note-to-self/ so I will start with the specs quoted re the current and voltage.
I dont know where the cathode is however. I've included photos for you from each angle. Please see the six thumbnails attached.
I cannot determine a characteristic bevel or depression as per, for example, the picture immediately below.
Can you advise me please.
