SMD LED as light detector
Tejasvi471
Joined Jun 9, 2020
35
Hello Intelligent people,
I have successfully made Light detector using simple reversed biased clear package 5 mm RED LED and darlington transistors (attached circuit and Datasheet of detector LED)
I shine white/green LED light on that RED LED detector and it detects light.
Then I tried to use SMD LED instead of 5 mm RED LED I scavenged from somewhere. (attached pic)
SMD LED measures 3 mm by 3 mm and is of bright yellow color.
I actually don't know the part number of SMD LED.
Forward voltage of SMD is 3.4 V with 48 ohms of resistance.
I shined every color of light on it and It doesn't work, any guess why ?
Danko
Joined Nov 22, 2017
2,231
Your bright yellow SMD LED is phosphor based LED.
It contains blue LED (3.4V forward voltage), coated by phosphor+epoxy.
Blue LED is sensible to UV light, but phosphor coating shields LED from external UV.
Tejasvi471
Joined Jun 9, 2020
35
oh man, i would have never known that. any idea how to remove that phosphor coating
dl324
Joined Mar 30, 2015
18,453
I have checked it and he is right, RED is sensitive to both green and blue, while blue one is only sensitive to Blue
These are subjective statements. LEDs as detectors will have a peak sensitivity near their emitted peak and will decrease at other wavelengths. From what I've read, the spectral response is narrow compared to photo diodes.
28,133
I have experimented with using LEDs as light sensors and some of them work well, some work poorly, ans many work not at all. Some green work and some red ones barely work. I have not determined how to predict what will work well and what will not work.
