Smd code to part number
esinior
Joined Apr 22, 2012
7
Hi
i have a smd part with probably mark "QO 11" or "Q0(zero) 11" on it, and its package is SOT89, i doubt its KTB1260 PNP transistor, but in measuring with diode mode of multimeter it shows number 1.4 between emitter and collector pins and its not open circuit, and .59 from collector to base and .8 from emitter to base , and these numbers doesn't match a pnp transistor, i couldn't find any part number and datasheet for it, does anybody have information for that part number?
I've attached pics of this part
34,974
It would help in the search if you told us what instrument or appliance the component came from or what the appliance does.
Also post a picture of the entire circuit board and a zoomed in view of the area where the component was located.
esinior
Joined Apr 22, 2012
7
It's a component on the PFC (power factor correction) section of a SPS (switching power supply) and i think it could be a shunt regulator too, but it's named Q on the board, I send pics of board and daughter board
