Smartphone lcd to usb-c
j0van
Joined Oct 23, 2019
Hello everybody, this is my first post, i don't have an electronics background that is why i write here for help,
I want to know if it is possible to convert smartphone lcd display to external with usb-c port, i did a little research and i found that most lcds use fcc cable, then i found ffc to usb-c connectors to aliexpress, so do i need an lcd controller board for this to work? if so can this be somehow simplefied since it is intended to be used with phone display, thank you for reading.
seanstevens
Joined Sep 22, 2009
323
I will just tell to forget it as it is way more complicated than that. Every display is different, commands, pins, protocols, its not just the connection.
kubeek
Joined Sep 20, 2005
5,796
Unless you find a board that does exactly what you need with the display that you have I would say it is nearly impossible. For someone who has ample experience with both phone lcds and usb such project would take about 3-6months of development depending on how easy it is to make the code for the processor to act as a usb video card.
