small signal model for bjt
alimash
Joined Oct 12, 2016
67
dear friends,
i have a general question about bipolar transistor
what is the need of small signal modeling?
thank you
35,312
Did you google small signal model?
A circuit designer needs to know two things:
1. What are the DC bias conditions of the circuit,
2. How does the circuit respond to a small AC signal on the input.
Which one do you think is small signal modelling?
alimash
Joined Oct 12, 2016
67
I know it is the second
At class we only use this model to calculate tow things:
-The voltage gain
'the low and high cutoff frequency
My question is:
if the goal was only power amplification;do we need
alimash
Joined Oct 12, 2016
67
-The voltage gain
My questions are:
-if the goal was only power amplification;do i need to go into the small signal modeling?
-is there any other reason to go into this model?
thank you
38,952
If you don't use the small-signal model then how would you calculate the power amplifier's gain and frequency response?
shteii01
Joined Feb 19, 2010
4,644
When someone says Power Amplification, they mean: amplify voltage and amplify current, at the same time.
What if you want to only amplify voltage?
What if you want to only amplify current?
See? No Power Amplification.
You are going to need a separate model.
