Small improvement to [CODE] tag
Alec_t
Joined Sep 17, 2013
15,158
Testing, testing ....
C:
    func convertP(P: Double, units: String)  -> Double {
        if units == "psi" {
            let P = P*51.71492410243892
            return P
        else if units == "atm"  {
            let P = P*760.0
            return P
        return P
Still not working for me :(.
18,170
Just verifying, with "code=objective-c":
Code:
        if units == "psi" {
            return P
            let P = P*760.0
            return P
        return P
Looks like it works! Cool. Note that technically this is Swift 2.0 code, a descendant of Objective-C.
NorthGuy
Joined Jun 28, 2014
611
Is there any way to make the gray text inside code tags less pale and more contrasty. It is gray on gray background. Almost impossible to read as is. Not to mention line numbers, which are practically invisible. Here's how I see it:
strantor
Joined Oct 3, 2010
6,875
I'm not sure if it's been fixed, or if it's a browser or website setting. Here's how it looks for me:
Does it look like my pic now for you? Or does it still look like your pic?
I'm using the old blue theme. Are you using the new orange theme?
strantor
Joined Oct 3, 2010
6,875
I use "blue" theme. It looks good now - like on your picture. Thank you for fixing it!
I surely didn't fix it, but I'll echo you: Thank you (to whoever fixed it). I was just trying to figure out whether someone else had in fact fixed it, or if I had some different settings than you.
