Small 2 x 35w amplifier board (import) does this look legit?
RogueRose
Joined Oct 10, 2014
375
I need a small amp for a set of speakers for a LCD screen. The output from the computer/dvd player will either be a headphone jack, component audio (Red/white), or USB is it can handle it.
2 x 35watt amplifier
It looks like the speaker outputs are on either side of the IC, Voltage input is at the front center and I guess the signal input is the " L GND R" towards the front right of the board. I guess the signal channels can share the same ground? (I never thought about that before, lol :) )
This board is about $5.50, IDK if that is a good deal or not, or if it will be adequate for driving speakers on a 24 - 29" LCD (so it isn't a home theater, just something for a small room). I have plenty of heatsink options so that shouldn't be an issue unless I need to add a fan, that is always a little bit of a bother.
So should this work alright?
38,803
Looks like a good buy.
Yes the inputs can share a ground (and typically do).
You probably won't even need a heatsink if it's just powering a couple peak watts of TV voice audio.
The lower the power supply voltage, the lower the dissipation for a given output.
You probably could get by with a lower end voltage (9V or so) if all you need is TV audio.
(How are you planning on powering it?}
You can try it without a sink at a typical program volume level and see how warm it gets after a few minutes of operation.
The worst-case would be if you listened to music at a high level.
RogueRose
Joined Oct 10, 2014
375
So if my raspberry pi, or whatever I use to send audio signal to the amplifier connects to the amplifier, do I need a pre-amp like this?
http://www.ebay.com/itm/Digital-Hifi-Amplifier-Stereo-Audio-Volume-Control-Combo-Kit-/141906952957
BTW, I'm planning on using a Rasp pi for this setup to play video/music on this monitor. Someone asked about how I am going to power the device and I'm really not sure ATM as IDK what the best options are. I am pretty sure the monitors I'm using have a 5 & 12v power supply built into the "control box" in the back of the monitor.
I'm really bad at reading the IC datasheets as all the numbers seem so far off from what is advertised, as to me it looks like this chip is designed for 2 channels x 6 watts.
but if this device is putting out 2 x 35 watts, then I would need at least 70 watts of power correct?
The datasheet says
"Absolute Maximum ratings"
-"operating supply voltage" Vod - 18v
-"DC Supply Voltage" Vs - 28v
-"Power Dissipation" Ptot - 36w (That is a lot of heat!!!)
"Electrical Characteristics"
-Supply voltage range - 8 - 18v
-Output Power - Single Ended min 5.5w - Typcl 6w - Bridge min - 18x Typcl 20w
So to me, it looks like if I am using 8 ohm speakers in stereo, then i'm getting MAYBE 6 watts / channel. But if I run mono/bridged, I get 20 watts (@ 4 ohm??). I could get 4 ohm speakers and bridge them to get 2 ohm, but I'm guessing I might get a lot of heat with that.
Alec_t
Joined Sep 17, 2013
15,156
If the pi puts out a high enough signal and the amp has a sensitive enough input then you don't need a pre-amp; just a volume control (potentiometer).
38,803
The amp has a gain of 20 (26dB) when connected for a bridge output, as your circuit is, so to get a 10W output into an 8Ω speaker requires about 0.45Vrms input.
You thus should not require a preamp.
