Hi there
I am wanting to connect a third party directional antenna to an IFM CR3131 CANwireless deivce to try improve the range. The CR3131 has a RP-SMA connection for the antenna, while the options I am looking at for antenna all have SMA connections. After some reading I found that RP-SMA connections are made prevent consumers from attaching non standard antenna to try increase the gain. Am I able to still use these antenna with an off the shelf SMA to RP-SMA adapter or is there more to it than that?
Here's some of the adapters I'm thinking of
https://www.segemart.com/1961305113...VgnDTtjLlZxlxy0fES_a9yVOLZhywVHhoCn_oQAvD_BwE
https://www.jaycar.co.nz/sma-plug-t...3aAbYUTRcfWihQuGl9gd7SKsis_S5tkRoCM_QQAvD_BwE
Cheers.
Cheers.
