Single phase two winding transformer
circuit.vinit
Joined Feb 4, 2017
6
A single phase two winding transformer is designed to operate at 400/200 volts, 50Hz.if the high voltage side is now energized from a 400Volts, 40 Hz source, the no load l.v side voltage would be what numerical value?
35,093
We don't know. The transformer might be frequency dependent or it might not be frequency dependent.
Ramussons
Joined May 3, 2013
1,572
If it's a reasonably high capacity transformer, you will get 200 V on the secondary. Of course, there will be more core losses with more heat generation.
