See figure attached for my attempt at part b).
What am I doing wrong? My voltage for the generator is slighty off.
I has an angle equal to -arccos(PF).See figure attached for my attempt at part b).
That was it!You chose to use the load current as your reference (0°), but it looks like in calculating -Vg + VTL + VL = 0 you switched to load voltage as the reference (VL = 860<0°).
(2 + j4)mΩ/kmjegues, how did you get the impedance of the transmission to be 0.2+0.4j
