sinc function
frankk88
Joined Jun 28, 2018
Hi everyone
Im trying to get an square in frequency with the signal generator, so I am trying to use the sinc function. I connected it to the spectrum analyzer and get a list of peaks with a distance between them equal to the frequency that I choose for the sinc function at the signal generator.
I have no explanation for that, could you help me to understand it please? what should I do to get a square function?
thank you very much!
35,320
What is the make and model of the function generator?
Does it not have a square function output? Almost every generator has a square wave output.
frankk88
Joined Jun 28, 2018
You are getting this ? Note y axis is linear, not log.
Regards, Dana.
I am getting this as a output of the signal generator, but the spectrum analyser is showing just a list of peaks, with a distance between them equal to the frequency that the signal generator is creating a new sinc funcion (for instance, if there is a sinc created each T seconds, the frequency between peaks is 1/T)
I dont need a square function in time, I need a square function in frequency, so I am using a sinc function in time. But I am not getting a square function in frequency
thank you both!
35,320
Can you show the results you are getting?
The transform of a rectangle is a sinc.
Hence the inverse transform of a sinc is a rectangle. Maybe you are getting the correct results.
35,320
That is just what I suspected. They are not Dirac deltas at all. They are the correct results as per quantization.
Remember that a discrete transform will give you discrete results. Connect the dots and you will have a rectangular output.
frankk88
Joined Jun 28, 2018
I think the dots are connected, as it is output of the signal generator. otherwise, How I can conect the dots?
