- Joined Jan 23, 2018
- 28,412
If it is a damaged cable the result will be immediately obvious. If not, then it is a simple fix that will last.
I have two different wireless mice, that use just one AA cell each.wireless devices are very thrifty on power requirements, they usually require 2 AA cells instead of the full USB’s 5 volts,
I've had several wireless mice. Some use one call and others use two. In the past, the mouse that I use all the time has lasted about two years on a battery. In recent years, I'm lucky to get much over six months (in the same mouse). But that's primarily an additional indication of how much worse today's batteries are getting.I have two different wireless mice, that use just one AA cell each.
So... he wants to convert his corded mouse to a wireless mouse in order to be able to misplace it or let it wander off???Consider though, that a mouse on a cord is much less likely to be misplaced or to wander off. Next, consider that perhaps the TS does not reside in an area having computer mouse stores on every corner.
Try these- lasts for 10 years on battery:I've had several wireless mice. Some use one call and others use two. In the past, the mouse that I use all the time has lasted about two years on a battery. In recent years, I'm lucky to get much over six months (in the same mouse). But that's primarily an additional indication of how much worse today's batteries are getting.
Here. Cheapest, most reliable solution:Well i am looking forward to solve this problem, as I am facing the same problem!
Regardless of the suggestions given; here's the deal: You'll need a new mouse body, one that can hold batteries. You'll also need wireless mouse circuit board. Basically - a new "Wireless" mouse. That's the shortest and most cost effective way of solving the issue of controlling your computer via wireless mouse. No need to reinvent the mouse. Just buy new. It'll be far more reliable than anything you're likely to build.Well i am looking forward to solve this problem, as I am facing the same problem!
