Looking to build a simple load tester for a 40V-4ah lithium Battery used in this case on the small electric lawn mower.
I have such a device for testing 12V, 5aH batteries used in stair lifts. It is simple. 2W, 4aH pre-LED car headlight bulb. Wires soldered to + and - on the bulb. Other ends attach to the battery poles. Light stays bright if the battery maintains load. Light quickly dims if the battery will not hold a load. Placing a volt meter on the poles at the same time provides how much voltage loss under load.
I am wishing to build a similar device for testing load on the above 40V battery. Can someone tell me the quickest method (& what size bulb to use) to do this? Not looking for something sophisticated. Just basic down & dirty tester. Thanks!
