Hi, everybody.
I'm trying to make a detector, that gets two-part signal and it drives two output signals (LEDs) that visually indicate that both parts of input are exist. When some part is absent, the appropriate LED is off.
1-part is sinusoid Vptp=60V, f=1Mhz. Full length of this part is not important.
2-part is 3÷5 pulses Vmax=+1260V÷2310V, Vmin=-600V, Pulse_width=200ns÷500ns.
I tried to rectify and reduce input and count some pulses from the first part (I suppose that if there are dozen pulses, that it's OK) and at least three pulses from the second part.
Guess what? It does not work. The first part is detected somehow, but it clears at the end, because the second part produce an enormous noise in all the circuit and on the CLEAR line too. I checked this with signal with no second part - the first LED remains ON. The second part is not detected at all, because when reduces at the point "Z2" it became a simple noise.
Pls, advise what can be done. May be this way is totally wrong and should be done in other way.
Thank you.
Thank you.
