signal and system
micro1
Joined Feb 22, 2015
79
hello every one
signal and system
properties of system Linearity
I did my problem
you can check my solution it is true?
33,326
I'm assuming that you mean
y[n] = x²[n-1]
If so, then this says that the present value of y is equal to the square of the previous value of x.
This is NOT the same as
y[n] = x²[n] - x²
This says that the current value of y is equal to the square of the current value of x minus the square of something that is not even at a defined time.
micro1
Joined Feb 22, 2015
79
if change the equation to
X1 = X1 [ Xn - X ]
X2 = X2 [ Xn -X ]
X3 = X1 +X2 ==> ( X1 [ Xn - X ] + X2 [ Xn -X ] )
X3 = X3 [ Xn -X ]
X3 = X1 +X2 ( linearity)
thank you for reply
33,326
X1 = X1 [ Xn - X ]
X2 = X2 [ Xn -X ]
X3 = X3 [ Xn -X ]
X3 ≠ X1 +X2 (no linearity)
thank you for reply
So, if you had the continuous time signal
y(t) = x²(t-1sec)
are you saying that you would rewrite this as
y(t) = x(x·t - x·1sec)
Does that make ANY sense whatsoever?
