Shoulder Banshee from Disney Animal Kingdom
My imagination has gotten me a bit over my head. I would like to get this Shoulder Banshee to make a different noise. In the end it will be a totally different “animal”. The design only uses power to make the sound and it only makes one sound when the mouth is open. I am guessing the sound going to be read only so most likely you all are going to say it can not be reprogrammed. That being said is there a way to still make it sound different perhaps with a different chip. I might be sharing too much information but I don’t know what is relevant and what is not.
IMAGE 1
The controller has 3 things you move putting tension on the wire and making the part move. There is no electricity involved.
The #1 AND #2 is the pulley that moves the head side to side.
The #3 is what wire that makes the sings open and close
The #4 is the wire that makes the mouth open and makes the sound.
When tension is put on the #4 wire it pulls down the blue piece near the yellow arrow and the teal spiral lowers with it pulling down the jaw to open its mouth. The bottom metal of the pole near the green arrow pushes the metal piece to make the circle complete and activate the power.
IMAGE 2
Written on the chip is
761460R1
PCBS-11115181-G2
IMAGE 3
The back of the chip is blank with the wires coming out
IMAGE 4
Overview
IMAGE 5
Outside – The toy is small so whatever the solution is must be small. The squares behind are 1-inch squares.
Thank you for any help you can send my way.
IMAGE 1
IMAGE 2
761460R1
PCBS-11115181-G2
IMAGE 3
IMAGE 4
Overview
IMAGE 5
