That pot has exceptional tolerances if the taper runs exactly 5K! Sorry if this seems like a silly question but are you measuring this in situ or completely disconnected from the circuit?It measures 360 at zero and 5360 at 5k.
You might be able to pre-load the M/S ratio a little by pulling the voltage level on pin 5.It measures 360 at zero and 5360 at 5k.
