I am working on repairing my uncles R965 Sherwood receiver which let out the smoke on the front left amp board rail after he spilled a small amount of coffee on it. The resistors on the front left track burned up along with 2 capacitors and a Ceramic Dual Emitter Resistor and all the transistors blew out as well. I ordered replacement parts for everything and tested and it produced very bad audio but it was working. Wanting to check if my replacement parts were bad I used the original transistors from another rail as they are all the same across the amp board. I left all the replaced resistors and the 1 electrolytic cap as the replacements but swapped a orange cap from the other rail. This made a huge improvement on the audio but at higher volume it still produces static/distortion. Im looking for help at what to look into next as i have tested all the resistors ohm values and they are all very close to the other rails. I will include the schematic and the pictures of the board/transistor heatsink array. The main problem I need to fix is the bad audio. I still will need to source replacements for the rail I borrowed from.
List of parts replaced
2SC2922 - Turned out to be a fake clone. Need to source a good one
2SA1216 - Turned out to be a fake clone. Need to source a good one
C3423x2
A1360x2
A1859A
C4883A
Resistors Various Ohms
2 Caps 1 Electrolytic 1 Polypropylene
C3423x2
A1360x2
A1859A
C4883A
