Setting values for LTspice digital device models?
Alec_t
Joined Sep 17, 2013
15,118
I would like to set a Vhigh or Vt value for a buffer or other model in the LTspice 'Digital' folder, so that the value is ratiometric with the supply voltage Vdd, e.g. Vt=Vdd/2.
If I know Vdd in advance it is simple to set Vt=2.5 (say). But what if Vdd is unknown or varying? How is Vt set then?
eetech00
Joined Jun 8, 2013
4,705
Hi
The digital "A" device parameters only accept values that are evaluated before a simulation run.
but you can use a B device to compute a value so it scales to the value that is set for the A device parameter.
For example, say your digital device should support an input range of 3-15 volts. You could leave Vhigh set to its default of 1v, then configure a resistor as an input pin to ground, label the input pin "in". Then use a BV device with its output connected to the input of the digital device. The value of the BV device would then be set to V=if(V(in)>3&V(in)<15,1,0).
Hope that makes sense.
