Series Zener Diodes
38,936
The are the same except for a possible difference in their combined impedances at breakdown (the zener impedance). You have to look at the respective data sheets to see.
to3metalcan
Joined Jul 20, 2014
263
The other way they're different is if the circuit also makes use of their .7V forward breakdown...obviously two diodes is going to give you two voltage drops instead of one!
MikeML
5,444
So put a 1n914 or 1n400x in inverse parallel with the two series Zeners...:D
to3metalcan
Joined Jul 20, 2014
263
Mike - heh, there may or may not be a few high-powered bass amps with exactly that arrangement lumped into them and doused in hot glue floating around the East Bay...
