thatoneguy
- Joined Feb 19, 2009
- 6,359
Is the voltage across C3 5V? If so, then it's correct. If not, then it's incorrect, because you can't end up with more voltage than you started with, the voltages need to sum to zero/source voltage.
I did that in post 14, the impedance is correct, I forgot an inversion for the total capacitance.This is getting confusing. Don't you want to post the X of every capacitor and we start from there?
Correct. and you ended up with the correct total current.XC1 is 1592 ohms, XC2 is 1062ohms, XC3 is 3980 ohms and XC4 is 796 ohms
