1.) buy the module suggested
2.) plug the module in to the PIC. Rx of module to TX of PIC and TX if module to Rx of PIC
3.) write program that will use the PIC's UART module to send data, with the correct configuration (baud rate, stop bits, parity, etc.) to be compatible with the USB to TTL module.
4.) use a terminal program (i.e. hyperterminal or TeraTerm) to connect to the virtual COM port that is created for the USB to TTL-again, with the same configuration add both the PIC and USB to TTL module are using and watch the data stream.
Remember post # 18?
Try reading. I refuse to repeat myself for the third time!
...see post #18, please actually read what I've written, I wrote that for you to understand what to do, yet you continue to ask the same question, this is now the forth time you've asked this question in this thread alone.
if you need help with configuring the terminal, I've never used RealTerm, so you'll have to consult, another resource: http://realterm.sourceforge.net/index.html#Baud_Rates__Ports
So, why you don't tell me what to do????????????
What do you think I've been doing!?
