When you plug in the module, is it detected by the system?NO, zero pcb ......
its not working now it is not giving power also, don't know why??
i have extra chip also but no SMD iron type to solder it!
Posting on two different forums isn't the problem. The problem is when you take work given to you on one, and post it as your own on the other. That is a form of plagiarism, of which Ritesh has been guilty on MANY occasions.Plus, I saw your same thread elsewhere in the Electro-Tech Online forums. Keep it at one same place.
The thread OP had certainly one problem too which I should point out - he has no (or limited) exposure on C/C++. Like you said, he probably cut and pasted this somewhere and (probably) refuse to analyze the code. He should have a starter one or two semesters in basic programming courses, and if he had, he should be already writing his version of this code already.Posting on two different forums isn't the problem. The problem is when you take work given to you on one, and post it as your own on the other. That is a form of plagiarism, of which Ritesh has been guilty on MANY occasions.
This is why most people have stopped helping him. He's stealing the work from other people and is doing nothing on his own. Then he submits the work to his professors claiming he did it, when in reality it is the work of dozens of people online and he hasn't helped at all.
100% agreed. Once again though, that's the problem--he takes other peoples' code and posts it as his own, and refuses to learn it himself. That's why a lot of people have stopped trying to help him.The thread OP had certainly one problem too which I should point out - he has no (or limited) exposure on C/C++. Like you said, he probably cut and pasted this somewhere and (probably) refuse to analyze the code. He should have a starter one or two semesters in basic programming courses, and if he had, he should be already writing his version of this code already.
Programming is not where it's learned in just a mere few hours. It should be learned with passion and with full curiousity.
Actually, a minor/small prerequisite for microcontroller subjects is at least with a semester of digital electronics. No kidding - in my workplace/university, students NEED to pass digital electronics before they have to take Microcontroller Systems subject. No pass or no take equals to no Microcontroller subject.100% agreed. Once again though, that's the problem--he takes other peoples' code and posts it as his own, and refuses to learn it himself. That's why a lot of people have stopped trying to help him.
Ritesh, when you read this I want you to know--I'm not trying to be rude, I want you to wake up and see what's happening here. I'm trying to help you. If you keep doing it the way you are now, you will never learn anything, and you will be unable to pass your classes at the university and you will fail at a job later in life. It's time you start back at the basics and LEARN this stuff yourself. Otherwise you will get nowhere. You may think you can just ask us for help and get all the answers you need, and you probably think you can just keep doing that for the rest of your life. But that's wrong. One day we will not be here to help you. Same with people on other forums (I know you're a member on several, not just AAC and ETO). That time is coming soon that nobody will want to help you. You MUST start learning this ON YOUR OWN. If you don't, you're setting yourself up for failure.
So, what was the problem?OK, The problem was not module the USB cable was having some problem i was thinking that i have lost usb module ....
anyway, i have figure out the main cause of problem it was wrong parameter mention on usb module as i said when i short both terminal it work after that i have removed the rx wire from uC and changed tx to tx pin of usb module then it work fine there is no error..............
The rx should be connected to rx of module and tx to tx....So, what was the problem?
if(ch=='a');
f = 'a' ;
HSerout(f);
__delay_ms(250);
#include <pic.h> // pic specific identifiers
#define _XTAL_FREQ 20000000 // Xtal speed
__CONFIG(0x3F72); // Config bits
unsigned char ch;
unsigned char f;
unsigned char HSerin(void);
void HSerinit(void);
void HSerout(unsigned char f);
unsigned char *a= " Introduction to System Engineering Concepts Open loop and closed loop systems, model classification, performance criterion; Validation and testing of models, mathematical modeling " ;
void main(void) // program entry
int index = 0;
ADCON1 = 0x6; // Analogue off
HSerinit();
__delay_ms(150);
while(1) // endless Loop
HSerin();
if(RCREG=='b');
f = 'a' ;
HSerout(f);
__delay_ms(250);
void HSerinit()
TRISC = 0b10000000; // should ideally be set
SPBRG = 129; // 20Mhz xtal 9600 BAUD
TXSTA = 0x24; // TXEN and BRGH
RCSTA = 0x90; // SPEN and CREN
void HSerout(unsigned char f) {
while(!TXIF); // Wait for module to finish
TXREG = f; // ready to send
unsigned char HSerin()
{ while(!RCIF); // Wait for a character
return RCREG; // return character
I don't that might be the problem it used to initialize the UART..Why do you have "void HSerinit(void)" ? You create the prototype later on. The way you have it now, it won't know which one to run. Remove the first "void HSerinit(void)" line and try again.
where???It could definitely be a problem. Your program calls HSerinit(), but you have it declared twice--one with the initialization code and one without.
unsigned char ch;
unsigned char f;
