sepic converter
cabraham
Joined Oct 29, 2011
82
I would go w/ a buck-boost if isolation is not required. For isolated (off-line) converters, a forward converter would be my choice for these specs. Please be very careful. A thousand volts is never to be taken lightly.
Claude
12,130
It is possible, but relatively impractical. A SEPIC converter is one of several buck/boost topologies. I've tried one a couple of times, and always found them to be a bit quirky compared to other designs. But the big problem you'll have is the 9:1 input voltage range. That's a lot to ask from whatever the magnetic structure is. Standard parts and app notes probably won't work without a lot of adjusting.
12,130
Claude
Nice rig. How do you like the hammered ride, and how do you keep from chipping it when going for the tom?
cabraham
Joined Oct 29, 2011
82
I love the hammered ride, K custom model. I just hit the tom and avoid the ride, sometimes I end up hitting it anyway. Also FWIW, this K custom ride model can also serve as a crash. Not a true crash, as its weight makes it slow to respond. But if you want a very loud, and sustained crash, it works great. I really love the "K" series of cymbals, dark shimmering sound. I also have a lot of "A" series as well. They are brighter sounding. Thanks for the interest.
Claude
