Seeking Advice: Using NEMA 17
AKNO
Joined Jan 15, 2023
12
so i am using a NEMA 17 to push a ring from stack of 10 rings( Lowest ring ). Weight of the ring is around 100g and diameter is of 20 cm the problem is that I am not getting enough torque to return back to original position and even the required speed that I need. the motor driver I am using is TB660 it my first time to work with a NEMA motor . And the movement of motor shaft is restricted to 0-90 degree. I will attach a proper photo of setup soon.
Marley
Joined Apr 4, 2016
519
Reduction gearbox? So the motor does many turns for the output 90 deg. Will increase output torque.
Or reduction toothed belt drive.
MaxHeadRoom
Joined Jul 18, 2013
30,808
