I'm trying to succeed in a function pointer.
what is wrong with the sdcc compiler says:
syntax error: token -> 'code' ; column 18
#include <string.h>
char str1[10];
xdata unsigned int i;
xdata unsigned int ret;
code *call;
typedef void (code *callback); (void); // syntax error: token -> 'code'
extern callback xdata statefunc;
void main(void)
strcpy(str1, "testing");
#include <string.h>
char str1[10];
code *call;
void main(void)
