Hi, I have this program I got From,
http://hobby_elec.piclist.com/e_pic6_2.htm
i have built the board after designing it and printing it and now i have a problem i made the multiplexer in backward so it scrolls the wrong way!!!
i belive this should be fixable at the code level so what i need is to know how to change the code below to make it scroll the opisite way.
here is the code i am using
Rich (BB code):
; The signboard control processing
; Author : Seiichi Inoue
list p=pic16f84a
include p16f84a.inc
__config h'3ff2'
;**************** Label Definition ********************
lpcnt equ 0c ;Screen loop counter adr
scrnidx equ 0d ;Screen data index adr
w_save equ 0e ;W register save adr
s_save equ 0f ;STATUS reg save adr
scrnhd equ 10 ;Screen table head adr
tm_cnt equ 20 ;Time adjust counter adr
e_adr equ 21 ;EEPROM data adr
e_check equ 22 ;EEPROM end check cnt adr
s_loop equ 23 ;Screen data loop cnt adr
s_index equ 24 ;Screen table index adr
s_work equ 25 ;Screen data work area
;* Time adjust *
;This data decides a scroll speed. Basic rate is 26msec.
tm_adj equ 0c ;Time adjust(26msec x 12)
;* EEPROM data size *
;If the data size is 30 bytes, then simply set d'30'.
e_size equ d'32' ;EEPROM data size
;*************** EEPROM Data Definition ***************
org h'2100'
de b'11111111'
de b'01111000'
de b'10111111'
de b'11011111'
de b'10111111'
de b'01111000'
de b'11111111'
de b'11111111'
de b'11000011'
de b'10111101'
de b'01111110'
de b'00000000'
de b'11111111'
de b'01110110'
de b'01110110'
de b'00000000'
de b'11111111'
de b'00000110'
de b'01110110'
de b'01110000'
de b'11111111'
de b'10000001'
de b'01111110'
de b'10000001'
de b'11111111'
de b'01111111'
de b'01111111'
de b'00000000'
de b'11111111'
de b'10011001'
de b'01111110'
de b'10000001'
;**************** Program Start ***********************
org 0 ;Reset Vector
goto init
org 4 ;Interrupt Vector
goto int
;**************** Initial Process *********************
org 5
init bsf STATUS,RP0 ;Change to Bank1
clrf TRISA ;Set PORTA to Output mode
clrf TRISB ;Set PORTB to Output mode
movlw h'07' ;TOCS=0,PSA=0,PS2/1/0=111
movwf OPTION_REG ;Set timer condition
bcf STATUS,RP0 ;Change to Bank0
movlw h'00' ;Set timer value
movwf TMR0 ;TMR0 = 0 (255 counts)
movlw tm_adj ;Set time adjust value
movwf tm_cnt ;Save time adjust
clrf e_adr ;Clear EEPROM data adr
movlw e_size ;Set EEPROM data size
movwf e_check ;Save EEPROM end check
movlw h'a0' ;GIE=1,TOIE=1
movwf INTCON ;Interruption enable
;************** Screen Load Process *******************
screen bsf INTCON,GIE ;Interrupt enable
movlw d'16' ;Set loop count
movwf lpcnt ;Save loop count
movlw h'0f' ;Set screen index
movwf scrnidx ;Save index
bcf INTCON,GIE ;Interrupt disable
scrnlp movlw h'ff' ;Set LED OFF data
movwf PORTB ;Output Data
movf scrnidx,w ;Set Position
movwf PORTA ;Output Position
movlw scrnhd ;Set Table head address
addwf scrnidx,w ;Head + Index
movwf FSR ;Set Table address
movf INDF,w ;Read Data
decf scrnidx,f ;Index - 1
decfsz lpcnt,f ;Loop end ?
goto scrnlp ;No. Next line
goto screen ;Yes. Next screen
;************ Begin Interruption Process **************
int movwf w_save ;Save W register
movf STATUS,w ;Read STATUS reg
movwf s_save ;Save STATUS reg
btfsc INTCON,T0IF ;Time out interruption ?
goto timer_int ;Jump to Timer process
goto init ;Reset(Illegal interrupt)
;************ END of Interruption Process **************
int_end movf s_save,w ;Read saved STATUS reg
movwf STATUS ;Recover STATUS reg
swapf w_save,f ;Read saved W register
swapf w_save,w ;Recover W register
retfie
;*********** Time-out interruption Process ************
timer_int
bcf INTCON,T0IF ;Clear timer int flag
decfsz tm_cnt,f ;Time over ?
goto int_end ;No. Retry
;************ Screen data shift Process ***************
movlw d'15' ;Set loop count
movwf s_loop ;Save loop count
movlw scrnhd ;Set screen head adr
movwf s_index ;Set screen adr
loop incf s_index,w ;Inclement index
movwf FSR ;Set read addres
movf INDF,w ;Read data
movwf s_work ;Save data
movf s_index,w ;Read index
movwf FSR ;Set write address
movf s_work,w ;Recover data
movwf INDF ;Write data
incf s_index,f ;Inclement index
decfsz s_loop,f ;All shifted ?
goto loop ;No. Continue.
;i belive this is where the message moves
;************** New data write Process ****************
movf e_adr,w ;Read EEPROM address
movwf EEADR ;Set EEPROM address
bsf EECON1,RD ;Start EEPROM reading
movf EEDATA,w ;Read EEPROM data
movwf INDF ;Write new data
incf e_adr,f ;Inclement data address
decfsz e_check,f ;End of EEPROM data ?
goto int_end ;No. Return
goto int_end ;Return
; END of signboard control processing
end
any help would be appreciated i am very new to this
