scr
ohorit
Joined Mar 8, 2008
12
i want to know 3 things.if anyone can help me i will be so thankful.
1.why scr does not latch in ac circuit
2.how to control high voltage using scr
3.how to control load current using scr
S_lannan
Joined Jun 20, 2007
246
for the first question i'd say it would be good to post the circuit, the question is worded in a tricky way.
for the second question controlling high voltage is no different from controlling low voltage except you would use a high voltage scr.
for the third question i'd say the scr doesnt really control current it simply conducts at a set part of the input waveform which in turn will change the average current and voltage delivered to the given load.
i was aware that the given text didn't directly answer you questions but i thought it would be easier to come to a conclusion if you knew the theory of the device in question.
hope this helps
