Why is scope bandwidth by thumb rule approx equal to 0.35/t(rise time) and not 0.35/t(fall time) ? In some logic families fall time is faster than rise time
Because from the perspective of the scope, there is no difference between the two: a scope's "risetime" is the apparent time, as viewed on the scope trace, that a signal takes to transition from one voltage level to another, even though that transition is actually instantaneous.Why is scope bandwidth by thumb rule approx equal to 0.35/t(rise time) and not 0.35/t(fall time) ?
That refers to the rise time and fall time of the logic's output, and has nothing to do with calculating the scope bandwidth.In some logic families fall time is faster than rise time
That's exactly what would happen; if the scope risetime is of the same magnitude as that of the signal you're trying to evaluate, the rise/fall time of the signal will appear to be slower than it actually is.OBW0549, for logics with a faster fall time , assuming I have a scope with bandwidth Just about covering the rise time of such a logic , if I did want to measure the HIGH TO LOW transition time of signals in this logic family through observation on such a scope , the measurement would be in error because due to the the higher harmonics at the transition being beyond scope bandwidth? Would I end up measuring apparently a slower rise time than actual ?
Thank youThat's exactly what would happen; if the scope risetime is of the same magnitude as that of the signal you're trying to evaluate, the rise/fall time of the signal will appear to be slower than it actually is.
Solution: faster scope.
Hi,Why is scope bandwidth by thumb rule approx equal to 0.35/t(rise time) and not 0.35/t(fall time) ? In some logic families fall time is faster than rise time
Because it's the same, fall time is just a negative rise time. What matters is that there is a semi-instantaneous change in voltage level, the direction is irrelevant.Why is scope bandwidth by thumb rule approx equal to 0.35/t(rise time) and not 0.35/t(fall time) ? In some logic families fall time is faster than rise time
Thread starter | Similar threads | Forum | Replies | Date |
N | Leader Model 300 Dmm/Scope | Datasheets, Manuals & Parts Identification | 2 | |
Y | doing AC sweep transfer function using MSO8104A scope | Analog & Mixed-Signal Design | 0 | |
F | Building A Clip On IR Scope | General Electronics Chat | 3 | |
D | o scope bandwidth | General Electronics Chat | 30 | |
G | Scope Bandwidth? | General Electronics Chat | 1 |
