schneider electric - Lisse socket
thor21
Joined Sep 29, 2024
435
hello,
i want to install/ recess into the brick wall back box and cover it using blank plate
back box
https://www.se.com/nl/en/product/5961035/thorsman-cybd40-mounting-box-double-white/
plate
https://eshop.se.com/ae/lisse-white-moulded-blank-plate-2-gangs-matt-white-ggbl8020s.html
chatgpt told me i need the following terminals
https://www.conrad.com/en/p/schneider-electric-5961505-screw-terminal-1-pc-s-2933776.html
I am not sure if abovementioned components will fit, or do i need also?
https://www.ebay.co.uk/itm/205696328988
Seems that to complete one module one has to got another uni degree :)
thanks
28,312
The type of terminals you need will depend on what sort of wires for what voltage you run to the box.And if that goofy site did not ask about that initially, how can it know??
lichurbagan
Joined Jul 4, 2025
137
hello,
back box
plate
thanks
The Lisse 2-gang blank plate fits the CYB-D40 box. You must add screw pillars (part 5961505) to mount it.
Without them, the plate has nowhere to screw in. Each box needs two screw pillars, one top and bottom.
They snap into the D40 and take the plate’s screws. Buy extra if using two single modules instead. The 5961505 pillars may be discontinued but still sold. Buy from a reliable distributor or online supplier. Once fitted, your plate and box will align perfectly.
lichurbagan
Joined Jul 4, 2025
137
@lichurbagan thanks, lovely, will try.
can i also use that one? without need of pillars?
https://www.se.com/ee/et/product/5961005/thorsman-cybd30-mounting-box-double-white/
do i also need that frame? https://www.ebay.co.uk/itm/205696328988
Schneider Electric - Lisse White Moulded, Double Socket Surround, 2 Gangs
You can use D30. It’s shallower than the D40 version. You’ll have less internal depth for wiring and mounting. Using the D30 doesn’t automatically eliminate the need for screw pillars. The faceplate still needs something solid to screw into. If the D30 box is supplied without internal screw pillars, you’d still need them (or a compatible alternative) to mount the plate securely. You need a a surround/plate is what covers the box front. You will need a compatible surround/plate that matches the back-box size. If the D30 box fits the Lisse White Moulded, Double Socket Surround, 2 Gangs surround size (2-gang, same front dimensions) then yes you can use it.
lichurbagan
Joined Jul 4, 2025
137
Yes. The Thorsman CYB‑D30 double mounting box (ref 5961005) is listed as coming with two M3 screw pillars (“2 kruvisambad M3”) built‑in.
So that means you shouldn’t need to purchase additional separate screw pillars for that box, unlike the D40 version. https://www.se.com/ee/et/product/5961005/thorsman-cybd30-mounting-box-double-white
Regarding the surround, check the dimension. I cannot exactly understand the dismension from the pic.
