Scanner adaptor voltage goes to 0 after connecting
sangpo
Joined Aug 17, 2013
91
Dear expertises,
1, next morning my scanner not powering at all.
2. It is powering when i connevt other adaptor of same brand of scanner.(so scanner is ok)
3. I checked voltage of my adapdaptor with dmm, and it shows 12 volt. (Scanner is rated 12 V )
4.again i connected adaptor to scanner.but no powering. Then i disconnect it from scanner, .without adabptor being switching off the main power socket, I checkhed voltage, but volt is zero.
Then i switch off and switch on again the main power socket to check votage again, then the votage is showing 12 V,
So what is possible cause of this problem?
1. Resistor .?
2.capacitor? Diode?
3. Or what else
Thank you all
Alec_t
Joined Sep 17, 2013
15,152
1. Resistor .? 2.capacitor? Diode?
Could be any or all of those, as well as any semiconductor device or a poor connection. I'd vote for the latter, if plugging and unplugging the connector causes a change in the output of the adapter.
Then i switch off the main power socket to check votage again, then the votage is showing 12 V
I don't see how you can get 12V out (other than very briefly as a capacitor discharges) when the mains power is off.
sghioto
Joined Dec 31, 2017
8,745
Agree with Alec_t. Suspect an intermittent connection in the cord, most likely at the connector which plugs into the scanner.
SG
AlbertHall
Joined Jun 4, 2014
12,645
It could also be an overactive protection circuit in the power supply, which could also be caused by almost anything.
I don't think we are helping much.
sangpo
Joined Aug 17, 2013
91
Sorry
It is , that i switch off and then gain switch on the main power socket to check voltage again, then the votage is showing 12 V,
