Hello all. I have a DC energizing a project I am working. As for safety, I installed a micro switch on the door (interlock) which opens the circuit/power to the DC set. I know I can use relay logic (relays with PB) so that every time I want to restart set after closing door, I push a start button. However, I would like that the voltage only starts when the knob/input voltage is zero like some sophisticated sets I have seen that have "zero voltage start". I would like to include this without having to use another micro switch. Is there a simple basic circuit I can make that will only let you restart the set when voltage knob is at zero?
