Safe to Solar Trickle Charge Lithium Battery (18650)?
ConnectedWeAre
Joined Oct 22, 2019
6
Greetings,
I present a question purely about safety. Is it safe to charge an 18650 with a low-current/constant-voltage setup as below? I have posed various questions to Google and everything seems to point to the "right" way to charge batteries. In short, is it safe to use an LDO or other constant voltage device to charge an 18650 to 4.2v?
Solar = 1W 6V
LDO = LM2596 set at 4.2v output
18650 = 9800mah lithium ion
All signs seem to point to yes. The maximum 0.02C charge rate is low enough to satisfy all stages of "safe" lithium ion charging. And, assuming the battery voltage is never discharged below 3.2v, could a device be powered directly from the battery at the same time?
Thanks for any help. The attached picture show the setup with every piece except the melted solder. Is the diode even needed?
oz93666
Joined Sep 7, 2010
742
First off a small point about your cell ... you think you have a "18650 = 9800mah lithium ion " ... you haven't ... the largest capacity on the market is 3500mAhr ... none have been made with over that capacity , Chinese manufacturer just write anything on the wrapper ,it's probably about 2500 , if you are lucky ... You can trust panasonic , sony etc ... that's why they cost more...
As for charging you say "maximum 0.02C charge rate" for this cell ... that's wrong all 18650s can handle 0.5C charge (around 1A)
I don't know why you want to trickle charge?? You should have a BMS on this cell ($1 ebay many different types ) this will prevent any imaginable problems , you just leave it connected to charger and the BMS circuit will switch charging on and off when required ... ebay.co.uk/itm/1S-3-7V-3A-PCB-BMS-Protection-Board-for-1-Pack-18650-Li-ion-lithium-Battery-Cell/252580125401?epid=15024613399&hash=item3acef2dad9:g:krsAAOSwzaJX60Fj
ConnectedWeAre
Joined Oct 22, 2019
6
I can't afford a bigger solar panel, so very low 0.1C-rating is my only power source (thank you for fact check; it's a pack of six so I bet 9800/6 = 1633mah).
I don't want the charge current to cut out at 4.2v.
Is it safe to "overcharge" at 4.2v? I was assuming nothing happens if the 4.2v battery meets 4.2v charge current.
oz93666
Joined Sep 7, 2010
742
They really are selling those as 9800 each cell .Beware of any cheap brand , I bought some ultrafire , when I removed the top +ve terminal button the cell +ve terminal had spot welding marks indicating it had been used ... taken from scrap laptop batteries ... it's a big industry , when a laptop battery appears dead , some cells still have some life left , these are taken out and given a new plastic sleeve and sold as new
You must stop charging at 4.2 or the cell will not last long or even malfunction completely ... if you get the BMS I linked to you can connect your panel through that to the cell and everything will be taken care of
BobTPH
Joined Jun 5, 2013
11,647
You do realize that, at 0.02 C charging, you will need 50 hours of charging for each hour of use, right?
That does not sound very practical to me. What is your usage scenario?
Bob
