- Joined Jan 23, 2018
- 28,390
I also am suspecting that there must be another factor in the failure. Possibly a burst of higher voltage, high enough to do damage but short enough to not pop fuses. But the first thing to check, because it would be obvious and easy to detect, will be continuity between the power transformer and the supply rectifiers. If that continuity is OK, or even if not, check the rectifier diodes for being either open or shorted. A burst of over-voltage can cause that sort of failure.
Then check for the voltage across the 10,000 mfd capacitors, relative to the supply common, which might be chassis ground..It should be close to the posted value of 41 volts. If not, the rectifier bridge is suspect. But if the 41 volts is good, then check the regulator outputs, 15 volts positive and negative.
Either the supply is working or not, it is the easiest to check and the cheapest to repair.
