Rtos- progran goes to exit.c
poojapatankar
Joined Feb 12, 2021
I am working on TM4C123GPM. Developing rtos. There are few create thread functions in my main function. As soon as I do configuration of input output pins, the program goes to exit.c and then to abort function inside the exit.
if I put a while(1) loop inside main then it doesnt go to exit. I wanted to know if infinite while loop can be used inside main function for rtos?
poojapatankar
Joined Feb 12, 2021
You need to show your code and tell us which RTOS you are using.
C:
// RTOS Framework - Spring 2021
// J Losh
// Student Name:
// TO DO: Add your name(s) on this line.
//        Do not include your ID number in the file.
// Add xx_ prefix to all files in your project
// xx_rtos.c
// xx_tm4c123gh6pm_startup_ccs.c
// xx_other files (except uart0.x and wait.x)
// (xx is a unique number that will be issued in class)
// Please do not change any function name in this code or the thread priorities
// Hardware Target
// Target Platform: EK-TM4C123GXL Evaluation Board
// Target uC:       TM4C123GH6PM
// System Clock:    40 MHz
// Hardware configuration:
// 6 Pushbuttons and 5 LEDs, UART
// LEDS on these pins:
// Blue:   PF2 (on-board)
// Red:    PE1
// Orange: PE2
// Yellow: PE3
// Green:  PE4
// PBs on these pins
// PB0:    PA7
// PB1:    PA6
// PB2:    PA5
// PB3:    PA4
// PB4:    PA3
// PB5:    PA2
// UART Interface:
//   U0TX (PA1) and U0RX (PA0) are connected to the 2nd controller
//   The USB on the 2nd controller enumerates to an ICDI interface and a virtual COM port
//   Configured to 115,200 baud, 8N1
// Device includes, defines, and assembler directives
#include <stdint.h>
#include <stdbool.h>
#include "tm4c123gh6pm.h"
#include "uart0.h"
#include "wait.h"
// REQUIRED: correct these bitbanding references for the off-board LEDs
#define BLUE_LED     (*((volatile uint32_t *)(0x42000000 + (0x400253FC-0x40000000)*32 + 2*4))) // on-board blue LED
#define RED_LED      (*((volatile uint32_t *)(0x42000000 + (0x400243FC-0x40000000)*32 + 1*4))) // off-board red LED
#define ORANGE_LED   (*((volatile uint32_t *)(0x42000000 + (0x400243FC-0x40000000)*32 + 2*4))) // off-board orange LED
#define YELLOW_LED   (*((volatile uint32_t *)(0x42000000 + (0x400243FC-0x40000000)*32 + 3*4))) // off-board yellow LED
#define GREEN_LED    (*((volatile uint32_t *)(0x42000000 + (0x400243FC-0x40000000)*32 + 4*4))) // off-board green LED
#define PUSHBUTTON0  (*((volatile uint32_t *)(0x42000000 + (0x400043FC-0x40000000)*32 + 7*4))) // off-board PUSHBUTTON0
#define PUSHBUTTON1  (*((volatile uint32_t *)(0x42000000 + (0x400043FC-0x40000000)*32 + 6*4))) // off-board PUSHBUTTON1
#define PUSHBUTTON2  (*((volatile uint32_t *)(0x42000000 + (0x400043FC-0x40000000)*32 + 5*4))) // off-board PUSHBUTTON2
#define PUSHBUTTON3  (*((volatile uint32_t *)(0x42000000 + (0x400043FC-0x40000000)*32 + 4*4))) // off-board PUSHBUTTON3
#define PUSHBUTTON4  (*((volatile uint32_t *)(0x42000000 + (0x400043FC-0x40000000)*32 + 3*4))) // off-board PUSHBUTTON4
#define PUSHBUTTON5  (*((volatile uint32_t *)(0x42000000 + (0x400043FC-0x40000000)*32 + 2*4))) // off-board PUSHBUTTON5
#define BLUE_MASK      4
#define RED_MASK       2
#define ORANGE_MASK    4
#define YELLOW_MASK    8
#define GREEN_MASK    16
#define PB0_MASK       128
#define PB1_MASK       64
#define PB2_MASK       32
#define PB3_MASK       16
#define PB4_MASK       8
#define PB5_MASK       4
void initHw()
    // Configure HW to work with 16 MHz XTAL, PLL enabled, system clock of 40 MHz
       SYSCTL_RCC_R = SYSCTL_RCC_XTAL_16MHZ | SYSCTL_RCC_OSCSRC_MAIN | SYSCTL_RCC_USESYSDIV | (4 << SYSCTL_RCC_SYSDIV_S);
       SYSCTL_GPIOHBCTL_R = 0;
       SYSCTL_RCGCUART_R |= SYSCTL_RCGCUART_R0;
       SYSCTL_RCGCGPIO_R |= SYSCTL_RCGCGPIO_R0|SYSCTL_RCGCGPIO_R4|SYSCTL_RCGCGPIO_R5;
       _delay_cycles(3);
       // Configure LED pins
       GPIO_PORTF_DIR_R |= BLUE_MASK;
       GPIO_PORTE_DIR_R |= RED_MASK| ORANGE_MASK| YELLOW_MASK|GREEN_MASK;
       GPIO_PORTE_DR2R_R |= RED_MASK| ORANGE_MASK| YELLOW_MASK|GREEN_MASK;
       GPIO_PORTF_DR2R_R |= BLUE_MASK;
       GPIO_PORTF_DEN_R |= BLUE_MASK;  // enable LEDs
       GPIO_PORTE_DEN_R |= RED_MASK| ORANGE_MASK| YELLOW_MASK|GREEN_MASK;
       GPIO_PORTA_DIR_R &= ~PB0_MASK|~PB1_MASK|~PB2_MASK|~PB3_MASK|~PB4_MASK|~PB5_MASK;
       GPIO_PORTA_DEN_R |= PB0_MASK|PB1_MASK|PB2_MASK|PB3_MASK|PB4_MASK|PB5_MASK;
       GPIO_PORTF_PUR_R |= PB0_MASK|PB1_MASK|PB2_MASK|PB3_MASK|PB4_MASK|PB5_MASK;
// RTOS Defines and Kernel Variables
// function pointer
typedef void (*_fn)(void);
// semaphore
#define MAX_SEMAPHORES 5
#define MAX_QUEUE_SIZE 5
typedef struct _semaphore
    uint16_t count;
    uint16_t queueSize;
    uint32_t processQueue[MAX_QUEUE_SIZE]; // store task index here
} semaphore;
semaphore semaphores[MAX_SEMAPHORES];
#define keyPressed 0
#define keyReleased 1
#define flashReq    2
#define resource    3
// task
#define STATE_INVALID    0 // no task
#define STATE_UNRUN      1 // task has never been run
#define STATE_READY      2 // has run, can resume at any time
#define STATE_DELAYED    3 // has run, but now awaiting timer
#define STATE_BLOCKED    4 // has run, but now blocked by semaphore
#define MAX_TASKS 12       // maximum number of valid tasks
uint8_t taskCurrent = 0;   // index of last dispatched task
uint8_t taskCount = 0;     // total number of valid tasks
uint32_t heap[4096];
// REQUIRED: add store and management for the memory used by the thread stacks
//           thread stacks must start on multiples of 4 bytes
struct _tcb
    uint8_t state;                 // see STATE_ values above
    void *pid;                     // used to uniquely identify thread
    void *spInit;                  // location of original stack pointer
    void *sp;                      // location of stack pointer for thread
    int8_t priority;               // 0=highest to 7=lowest
    int8_t currentPriority;        // used for priority inheritance
    uint32_t ticks;                // ticks until sleep complete
    char name[16];                 // name of task used in ps command
    void *semaphore;               // pointer to the semaphore that is blocking the thread
} tcb[MAX_TASKS];
// RTOS Kernel Functions
// REQUIRED: initialize systick for 1ms system timer
void initRtos(void)
    uint8_t i;
    // no tasks running
    taskCount = 0;
    // clear out tcb records
    for (i = 0; i < MAX_TASKS; i++)
        tcb[i].state = STATE_INVALID;
        tcb[i].pid = 0;
// REQUIRED: Implement prioritization to 8 levels
int rtosScheduler(void)
    bool ok;
    static uint8_t task = 0xFF;
    ok = false;
    while (!ok)
        task++;
        if (task >= MAX_TASKS)
            task = 0;
        ok = (tcb[task].state == STATE_READY || tcb[task].state == STATE_UNRUN);
    return task;
bool createThread(_fn fn, const char name[], uint8_t priority, uint32_t stackBytes)
    bool ok = false;
    uint8_t i = 0;
    bool found = false;
    // REQUIRED: store the thread name
    // add task if room in task list
    // allocate stack space for a thread and assign to sp below
    if (taskCount < MAX_TASKS)
        // make sure fn not already in list (prevent reentrancy)
        while (!found && (i < MAX_TASKS))
            found = (tcb[i++].pid ==  fn);
        if (!found)
            // find first available tcb record
            i = 0;
            while (tcb[i].state != STATE_INVALID) {i++;}
            tcb[i].state = STATE_UNRUN;
            tcb[i].pid = fn;
            tcb[i].sp = 0;
            tcb[i].priority = priority;
            tcb[i].currentPriority = priority;
            // increment task count
            taskCount++;
            ok = true;
    // REQUIRED: allow tasks switches again
    return ok;
// REQUIRED: modify this function to restart a thread
void restartThread(_fn fn)
// REQUIRED: modify this function to destroy a thread
// REQUIRED: remove any pending semaphore waiting
// NOTE: see notes in class for strategies on whether stack is freed or not
void destroyThread(_fn fn)
// REQUIRED: modify this function to set a thread priority
void setThreadPriority(_fn fn, uint8_t priority)
bool createSemaphore(uint8_t semaphore, uint8_t count)
    bool ok = (semaphore < MAX_SEMAPHORES);
        semaphores[semaphore].count = count;
    return ok;
// REQUIRED: modify this function to start the operating system, using all created tasks
void startRtos(void)
// REQUIRED: modify this function to yield execution back to scheduler using pendsv
// push registers, call scheduler, pop registers, return to new function
void yield(void)
// REQUIRED: modify this function to support 1ms system timer
// execution yielded back to scheduler until time elapses using pendsv
// push registers, set state to delayed, store timeout, call scheduler, pop registers,
// return to new function (separate unrun or ready processing)
void sleep(uint32_t tick)
// REQUIRED: modify this function to wait a semaphore with priority inheritance
// return if avail (separate unrun or ready processing), else yield to scheduler using pendsv
void wait(int8_t semaphore)
// REQUIRED: modify this function to signal a semaphore is available using pendsv
void post(int8_t semaphore)
// REQUIRED: modify this function to add support for the system timer
// REQUIRED: in preemptive code, add code to request task switch
void systickIsr(void)
// REQUIRED: in coop and preemptive, modify this function to add support for task switching
// REQUIRED: process UNRUN and READY tasks differently
void pendSvIsr(void)
// REQUIRED: modify this function to add support for the service call
// REQUIRED: in preemptive code, add code to handle synchronization primitives
void svCallIsr(void)
// Subroutines
// Initialize Hardware
// REQUIRED: Add initialization for blue, orange, red, green, and yellow LEDs
//           6 pushbuttons
// REQUIRED: add code to return a value from 0-63 indicating which of 6 PBs are pressed
uint8_t readPbs(void)
    return (!PUSHBUTTON5 << 5) | (!PUSHBUTTON4 << 4) | (!PUSHBUTTON3 << 3) | (!PUSHBUTTON2 << 2) | (!PUSHBUTTON1 << 1) | !PUSHBUTTON0;
// YOUR UNIQUE CODE
// REQUIRED: add any custom code in this space
//  Task functions
// one task must be ready at all times or the scheduler will fail
// the idle task is implemented for this purpose
void idle(void)
    while(true)
        ORANGE_LED = 1;
        waitMicrosecond(1000);
        ORANGE_LED = 0;
        yield();
// REQUIRED: Remove this after task switching working
void idle2(void)
    while(true)
        RED_LED = 1;
        RED_LED = 0;
        yield();
// REQUIRED: Add other tasks here after task switching is complete
//           These will be provided in class
// REQUIRED: add processing for the shell commands through the UART here
void shell(void)
    while (true)
// Main
int main(void)
    bool ok;
    // Initialize hardware
    initHw();
    initUart0();
    initRtos();
    // Setup UART0 baud rate
    setUart0BaudRate(115200, 40e6);
    // Power-up flash
    GREEN_LED = 1;
    waitMicrosecond(250000);
    GREEN_LED = 0;
    // Initialize semaphores
    createSemaphore(keyPressed, 1);
    createSemaphore(keyReleased, 0);
    createSemaphore(flashReq, 5);
    createSemaphore(resource, 1);
    // Add required idle process at lowest priority
    ok =  createThread(idle, "Idle", 7, 1024);
    // Add other processes
    // REQUIRED: delete idle2 once task switching is working
    ok =  createThread(idle2, "Idle2", 7, 512);
// REQUIRED: create threads for additional tasks here
//    ok &= createThread(shell, "Shell", 4, 1024);
    // Start up RTOS
    if (ok)
        startRtos(); // never returns
    else
        RED_LED = 1;
    return 0;
