Try it and see if it works. Why all the theories?Hello:
I have below system:
may I know in system A, what supply should I used for MAX13431 VC? can I connect it to 3.3V or I must connect to 5V? and what is the maximum current for this power supply?
WTF theory are you talking about? Do you even know what you're talking about? No theories here, his initial concern, a valid one, was to avoid destruction by connecting parts with different Vcc voltages. We have put that concern to rest by careful examination of the datasheet. Now with half a meter of cable there should be no issues with signal degradation and excess capacitance -- so go ahead and run the experiment to see what happens. It should work just fine for a half duplex point to point connection.Try it and see if it works. Why all the theories?
Interesting. I've been using RS485 chips for years now. And it is my understanding that the termination resistors are there to dampen "signal bounce" when using long lines. But this is the first time I've heard that only one resistor is recommended for short cable lengths (makes sense, btw)Remember to put your one termination resistor on the cable. Never, ever put it in the product. You only need one termination resistor because the cable is so short.
"Read the data sheet"? BS what will the device do outside what is on the data sheet? No math about VCC required. If it works, it works, even if the parameters are not in the data sheet.WTF theory are you talking about? Do you even know what you're talking about? No theories here, his initial concern, a valid one, was to avoid destruction by connecting parts with different Vcc voltages. We have put that concern to rest by careful examination of the datasheet. Now with half a meter of cable there should be no issues with signal degradation and excess capacitance -- so go ahead and run the experiment to see what happens. It should work just fine for a half duplex point to point connection.
The termination should be on the cable system and not in the product because, in the product there will be a jumper, and it could be in or out. In a multi-drop application, if too many of those jumpers are in what happens? That's right you get a dozen or so 'termination resistors' in parallel and your transmit levels get seriously degraded. Next question, when things go wrong and you suspect there are too many termination resistors, how quickly can you make the determination? How many boxes do you have to open? You get the idea. Terminations are an integral part of the cable system and there is nothing that says the last device has to be at the end of the cable system.Interesting. I've been using RS485 chips for years now. And it is my understanding that the termination resistors are there to dampen "signal bounce" when using long lines. But this is the first time I've heard that only one resistor is recommended for short cable lengths (makes sense, btw)
My question here is, what do you mean the resistor should be placed on the cable and never in the product?
Do you mean that the resistor should not be mounted too close to the RS485 chip? What could happen if it were mounted in the product?
My naive assumption is that maybe a little distance is required between the resistor and the product (the RS485 chip) to make sure that no reflection reaches the product... am I right?
Q: Using the standard calculation for frequency and wavelength, what is the wavelength of 9.6 kHz?Here's an interesting short article about how to calculate RS485 termination resistors:
http://ltxfaq.custhelp.com/app/answers/detail/a_id/1382/~/rs485-&-rs422---when-is-termination-required?
I found this fact very interesting, btw:
"... for cables 2000 ft or less termination is not needed at 9600bps."
Would you believe me if I told you that I have not yet fully understood what common mode voltage is, and why it is an undesirable thing? I mean I've read technical articles about it, but I have yet to find one that explains things to me in simple, plain english.Receiver thresholds can do strange things when there is a high common mode voltage on them.
Thanks!... DC offset with AC information signal riding on it... that already says a lot.CAUTION: there may be complex situations where the following is not entirely accurate.
It happens in differential signaling. In very simple terms, you can think of it as a DC offset with an AC information signal riding on top of it. The differential receiver ignores the DC component of the input as long as it is within the common mode range, and only pays attention to the difference between the two inputs. This is exactly what you want over a long cable where the difference between two grounds can upset a single ended receiver with a fixed threshold.
Since long cables look like distributed capacitors they will hold a charge for a long time if there is no low impedance discharge path. It is the termination resistors that keep both long and short cables from maintaining a DC offset. With no differential transmitters driving the cable, both differential signal lines will go to the same potential.
You can formulate a more rigorous definition, but let's stick with simplified for the time being.
