RS485 RS422 communication
ak52
Joined Oct 15, 2014
241
Hello Everyone,
I have a usb to serial converter (RS422) ,and would like to interface it with a sensor which communicates over RS485,it is possible to do it with my serial converter?If so please tell me the connections required and how do i give them for a full duplex mode?
The serial converter has an FT232 which is connected to a MAX488CSA.
PLease help.
ak52
Joined Oct 15, 2014
241
converter was made by me ,basically it was for rs232 ,but we wanted RS422 communication cabability.I have never used RS422 before so i donot know how to connect it physically.
Sensacell
Joined Jun 19, 2012
3,785
RS-485 uses 2 wires to communicate bidirectionally.
You must be able to disable your transmitter to allow reception, your circuit cannot do that.
ak52
Joined Oct 15, 2014
241
I see,thanks for clearing that for me :)
What do i need to modify to make it compatable with RS422?
Also if my slave is also a RS422 device how will the connections be set up?
34,830
You can add a MAX485 or equivalent IC (e.g. SN75176) to your existing design to provide RS-485 signalling.
If the USB-to-TTL converter supplies the RTS signal, you can use this to enable the RS-485 transmittter (and disable the receiver) via the /RE and DE control signals on the MAX485
Otherwise, you can use the first transition of TXD to trigger a monostable multivibrator in order to control the /RE and DE control signals on the MAX485. Set the pulse duration of the monostable to be just longer than the duration of one character. This may or may not cause a "turn around" interference depending on your situation.
