RS-232 and MODBUS
Jassper
Joined Sep 24, 2008
103
I am looking for information on how to convert normal RS-232 to the MODBUS protocall. Any info would be appreciated.
Thanks
Jassper
Joined Sep 24, 2008
103
Depends on your application. See this link - http://www.lammertbies.nl/comm/info/modbus.html.
Very intuitive link, thanks.
What I want to do is connect a Touch screen to the Arduino useing the RS-232 communications, but the touch screen I want to use only communicates in MODBUS/Serial or MODBUS/TCP.
Can I simply program the controller to send the data in MODBUS format? Maybe I am over thinking here.
MariaL
Joined Sep 29, 2014
2
RS-232 is serial based ASCII communication. You could make a program that maps the ASCII commands into Modbus RTU registers and run it on an embedded controller that has memory available. For example you could run a C language based program on an embedded controller like the one I listed below. Click here for C Language programming demos. Click here to watch a training video on Modbus protocol. If you have any questions, let me know.
I-7188EX-MTCP: $349.00 Modbus/TCP Embedded Controller with 40 Mhz CPU and Real Time Clock Programmable in C Language. Converts Modbus RTU to Modbus TCP. Supports operating temperatures between -25 to 75°C. Can be piggy back din rail mounted on top of other modules. I-7188EXD-MTCP has a 7 segment LED display.
http://www.icpdas-usa.com/i_7188ex_mtcp_i_7188exd_mtcp.html
Maria Lemone
30,661
Thanks
An old post, before my time here.
Modbus and RS232 are two completely different things?
You can use Modbus over RS232, RS485 or ?
Modbus is a data packet format, RS232 is a serial transmission format method.
