I have two questions and I’m unsure on how to solve them.
Question 1
A 1KΩ load resistance is connected across a half-wave rectifier. The input supply voltage is 12V (rms) at 50 Hz, a 1000µF filter capacitor is added across the load resistor. Determine:
The ripple frequency.
The ripple factor.
The ripple voltage.
Question 2
Design the full-wave rectifier circuit with the CLC filter, when the ripple voltage is 0.118 V, the input frequency is 50Hz, and the rms voltage for the source is 12V, assuming the load is a pure resistor which is equal to 1KΩ, C1 is 100µF, C2 is 1000µF and the voltage drop across the diode is 0.7V.
Question 1
The ripple factor.
The ripple voltage.
Question 2
