RFID tag localization using cm710 4 RFID module
M.Z@in
Joined Aug 19, 2024
M.Zain here
I want to use cm710 4 RFID module, I am making a system for RFID tag localization in which I will implement Angle of Arrival estimation and other different algorithms to locate the coordinates of the RFID tags. Does anyone know how can I do this using this module. I think the antenna (Phased array) will be connected directly to the module and I will have to use an FPGA or a DSP processor or an SDR board to implement the algorithms which will be connected to the module via SPI, or UART etc. I dont know whether the module can give me the parameters like time of Arrival, RSSI etc that will be used in the AoA estimation.
Also I dont know if I can implement the algorithms directly on to the module without using any DSP,FPGA or SDR.
