PL239 on the radio's and BNC's on my scopeWhat connectors does your equipment use?
Just get a PL-239 female to BNC male adapter such as this.PL239 on the radio's and BNC's on my scope
Thanks...
Thanks all...Testing should be using a dummy load. You could go with an RF attenuator, but for even a 1000 W transmitter, a 100:1 oscilloscope probe works.
I think I used a dummy load from MFJ with PL259's, a "T" and some way to get to banana plugs and probed there. Or made a test point, I forget. It was a transmitter on an ISM band.
yep, I was thinking the very same thing about reducing power...Hi John - You weren't very specific about what you were trying to do, or what equipment you have; but I get your comment about being "new to all of this."
You don't want to just plug your transmitter into your scope with an adapter. The transmitter is expecting to see a load of around 50 ohms, and connecting it to a high impedance scope input will cause unpredictable behavior or may damage the transmitter. If the power output from the transmitter is more than a few watts, you will likely destroy the scope as well.
That's one of the reasons why KISS suggested a dummy load. You need to connect the transmitter output to a 50 ohm load that can handle the power level of the transmitter. A coax "T" connector makes the connection from the transmitter to dummy load, and provides a way to "tap" the signal for viewing on the scope. Coming off the T you can connect a resistor voltage divider. If your power output is modest (<100W, which is about 100V peak @ 50 ohms) a 10:1 scope probe may be OK.
There are a lot of articles and youtube videos on this topic. Google "monitor ham radio oscilloscope" or similar.
GL
