Dear all hello,
Once again i will call for your help.
My recent project is to drive an RF amplifier from a T11 car audio Bluetooth transmitter.
I have already manage to open the T11 based on a previous article and i am ready to stick the antenna wire to pcb board.
On the other hand the amplifiers circuit can be driven by an RF induction coil and the minimum power input should be 0,2 watt.
Now the one million questions are.
Is the T11 capable?
How i can match one to the other?
I was thinking to make a two turns coil and connect to one side the T11 antenna wire, and on the other a 15pf capacitor and then to ground.
The above coil will be positioned then side to side on the same longitudinal axis to the all ready existing coil of the amplifier.
Can anyone advice me please if that is correct or any other way to achieve?.
Thank you in advance for your support.
Dimi
Is the T11 capable?
Dimi
